Headlights not popping up on side lights
Lemon
Hello all
I know this has been talked about many times and there is a simple wiring fix for this as per "John Sims" car. I think you have put a diagram on here John on how to do it.
My question to you all, is there a Relay that would plug in place of said wires from Porsche that would do this to give it a factory look in the fuse box rather than wires and spade connectors?
Just a thought as I do like it tidy even in the fuse box [;)] Is that normal behaviour!!!!
Probably worth trying a relay from one of the later 'non popup'cars and see if it is the same as the wire/spade solution. Alternatively dismantle your relay and hide the wiring inside it before reassembly. You would still have to unplug the dim/dip fag packet in the drivers footwell
What is this Paul and what function after the relay wiring does this do?
