Headlights on Buzzer HELP ?
trackm3
First time out last nifght with the headlights on and the buzzer wont stop, anyone have any ideas on wiring colours etc, need to start somewhere, hoping its an earth but i dont have a wiring diagram or manual to know where to start ? Car is a square dash early 85 944 2.5
Martin
I've never come across a headlights warning buzzer on a 944? Is it an aftermarket fitting or was it fitted to early cars?
I've never come across a 944 with a warning buzzer either. My square dash never had it and my oval dash doesn't have it.
Stuart
See the attached diagram - This has been published on the web and I have it on my car. It's a pretty simple circuit so if a previous owner has fitted the same thing it should be easy enough to trace. Probably a loose/shorting wire. You should be able to locate the buzzer unit by ear.. it'll be under the dash on the driver's side, then trace the wires.
There was a lights-on/door open "gong" on US spec cars. Certainly on the early cars, not sure about the late ones. It is one of the most gorgeous sounding things I have ever heard, such that I used to open the door with the lights on on purpose just to hear it! Unfortunately it is also hideously expensive, otherwise I would probably have retro-fitted one to my UK car by now!
Tref.
