Headlights
Skooby6
So this week i have had to sort out the lower radiator hose which is fine i have no problem with that but she struck again last night.
I won't go into the details but i went for a drink with a girl from work last night and come 10 oclock i was off home except that i wasn't!! Started the car and the bloody headlights wouldn't come up. Now this worked out fine because obviously i couldn't drive home with no headlights [:D].
So i stayed the night and have tried to fix the problem today, because i assumed the issue was with the fuse but alas the rather nifty little fuse tester already in the fuse box tells me that the fuses are fine....So i'm stumped i don't know whether to laugh or cry.
watch out for your hands . if the lamps suddenly decide to move with your hands anywhere near .......... The late cars have the relays actually on the loom next to the headlights . Have you tried to raise the headlights on both main beam and dipped ? With any luck you might be able to wangle another night tonight [;)]
Good advice on the involuntary moving headlights jeez almost lost a finger. Turns out it was a loose connection somewhere. I'll have to work out another problem for next time [:D]
