Headlights
- Thread starter tiskev
Have you had the recall done that is supposed to fix this?
Recall W424- New vents for headlights, supposed to correct condensation issue.
tiskev
It has been back twice I think it may be cured,but won't really know until the conditions are right to test them. What did give me a shock was when replacing a front indicator bulb and seeing that apart from the headlight cage being broken and loose instead of a new seal it had had silicon slapped all around it.
tiskev
My headlamps have always misted up a bit - never really thought about it as they always clear when the engine warms them through or they dry up unaided.
I suppose it can't be good for them in the long run.
As your RS I suppose I should check and get a propoer answer for you good folks. Let me see what I can do.
Lazza
tiskev
My real problem occurs at 1500 m above sea level when I visit one of my sons at Meribel.
You cannot see anything. I was there a week ago and I dont think they steamed up.but we do not have winter conditions yet..But ,but ,but, I carried on to Geneva to visit an old pal and when I left it was throwing it down and I really could not see where I weas going..Thinking about it maybe the lights were naff. I got fed up with being overtaken by 206's and tucked in behind lorries till i got to Dijon .Once I could see where I was going I do not think many cars passed me.Ps should I swap it for a Range Rover Sport??
I find (like on our old Boxster) that the normal beam is quite dull and I often use the full beam when I wouldn't on non-Porsche models.
The new Boxster has Bi-Xenon and these are much better. I'll get them on my next Cayenne.
BTW my lights steam up on the drive on damp days, let alone when it rains!
Lazza
It seems that there is a mod pack as I think mark mentioned earlier (not technically a recall).
The mod replaces the seals around the lamps and introduces more drainage.
If you let me know your VIN number then I can get it checked to see if your car is due the mod pack.
Lazza
Helen Goff
No.1 Poster
cayenne@porscheclubgb.com thanks
