headlights..
dave_monster
Does anybody know if there is a separate relay for the headlight "flash" they work if you push the stalk away , but not of you pull it to flash them.. If there is, where is it please.. I know mine isnt an SC but I dont seem to fit in anywhere :rolleyes:
Thank you, I will dig the car out on Sunday and have a play! I replaced the switch only about 6 months ago so hopefully it wont be that again.
Many thanks again.. Dave.
I had a problem with flash as well as changing dipped/main occasionally - solved it by using a bit of fine emery paper between contacts in the switch. I think that arcing had caused the problem. Relays are the way to go as already suggested.
Dave Jones
