heated rear window queery
cococola
Would some of you nice people try something for me please?
If you remove the heated rear window fuse and then refit it,does your heated rear window relay click?
I have had a battery drain problem if left for 4 days and have traced the drain to the hrw.I have swopped another relay over and I do not get the click when refitting the fuse,however when I fit the original relay I get the click.[8|]
Trying to illiminate things
cheers!
What fuse are you talking about, if you mean the fuse that protects the heater itself then I cannot see how that would effect the relay coil at all as it should be on a separate circuit. Unless the first relay is somehow shorted out and damaged. How about putting the second relay you tried in and turning the heaters on, do you get a click then?
Fuse 13(the hrw) and I have swopped another relay with no clicking although everything still works the same.
I havent left it for the 4 days since to see if it works however I would like to compare with others
cheers!
