heated rear window switch
- Thread starter Guest
jerry911sc
You have accidentally put up a second new post on the same topic- it's easy to do when you are getting used to posting on the forum. If you go back to Bones' reply to your first post you can reply to it there (just cut and past your second post) so that people can follow it and help you.
I am a bit confused by your second post. Do you have a coupe or a targa? For a coupe the control switch for the heated rear window should just pull out 1 click and illuminate. As far as I've noticed mine does not turn it just pulls out once.
According to Bone's the targa has 2 positions but I have no experience of that.
Jerry
Do you have foglamps? Turn the headlamps on, pull your switch and the rear f/lamps will light up. If you rotate the switch the front fog lamps will light.
If you're sure it's the rear window heater switch can we assume someone has changed the switch assembly at some point and replaced it with a foglamp switch assembly?
Cheers,
Rich
engleflick
