Heated rear window
craig2105
Well, that was a bust.
Was trying to trace why my HRW was so lethargic. Found the left-hand connecting wire from strut to window was a bit knackered, so I fashioned a new one. Unfortunately, as I was gently pressing the new connector onto the spade connection on the window, it came away...
So now I have no means of connecting strut to window, and apparently soldering the connector back on might result in cracked glass.
Anyone got a magic solution for this please? Is there a reliable conductive adhesive or something that'll do the job? It's like driving a van without a working HRW this time of year...
Cheers, Craig.
Craig.
Yes there is a conductive adhesive just for this very problem.
Cant just remember its name at the mo, but if you can wait a few days i have a tube in the garage, ill dig it out and let you know.
It does work, as ive used it on a rear window.
Craig. its called,,, electro connector made by granville. Its a electrical circuit repair paint repair kit, and i have used it on a rear window to make a repair just like what you need to do...I hope it works for you...
