Heated seats
Rufus
After a 5 year absence I am now back in a 987.1 2005 Boxster S with low mileage and non working heated seats, can anyone recommend someone in Herefordshire or Worcestershire area for repair
Do the buttons light up when you press them?
Reason I ask is that is a common symptom of car going into "transport mode" which can happen when the battery goes flat. Other symptoms ( they don't always do this) is if car has headlight washers they stop working, and I have read the interior lights only operate with the key in the ignition and other "oddities"
If so ( especially the buttons dont light up) then you probably need a diagnostic (porsche piwis) operation called a handover reset - makes the car relearn it's fitted options.
There could be other reasons why the seats don't work of course - they only operate when the cabin temp is in a certain ( fairly wide ) range - that is detected by the cabin temperature sensor - those have been known to go faulty and give weird readings causing the car to decide to "ignore" the heated seat request.
You likely need to start with a independent ( or a local club member ) who has access to porsche piwis - they can run a handover reset and also look for live readings from the cabin temp sensor if that doesnt resolve. Its a few mins of work to do, I suggest reaching out to local region to see if they know of anyone in the club locally with the kit - it may just need a reset rather then a fix.
Update on the problem thanks to Cotswold Porsche Specialists the heated seats are now working again
They did not use PIWIS as my car predates that system instead clearing all codes after having a new battery
Hmm. Ok. Both PIWIS II and III cover 987.1 (and earlier models) but moot point since it it’s sorted.
