Bullet11300
Hi - I own a 981 Spyder 2015 (late) Does anyone know if there are any options to retrofit a heated steering wheel to this model? I know gloves are an option, which I will look into. Thank you.
The clock spring it the connector that sits between the steering column and the wheel - it carries the connections for all the steering wheel wiring and copes with the rotation of the wheel by having a coil of wire housed in in - hence "clock spring". Its not the bit the stalks bolt to its the bit the wires from the steering wheel , and the car harness connect to On the 987.2 there are two flavours of clock spring - one that carries the heated wheel connectors, one that doesn't, it also carries the steering wheel angle sensor (used for stability control) - so you have to be careful when swapping - or have access to the piwis diags to re-calibrate the steering angle sensor.MatHaz said:Malarcy- I’d be interested in what you needed to do to change the clock spring over? Was it complicated? I think the clockspring is the part that all column stalks attach to? Which clockspring did you swap to? Any further info gratefully received. Thx
