Chaps,
Quickie.
Am I right in thinking that S2's have heated wash jets? I can see there are wires going to the back of the jets, and assume they are heated.
Am I also right in assuming that these heaters come on when the rear window demister is turned on?
The reason I ask is that the wash jets froze up on Monday (driving from E London to Birmingham and back, via Guildford), despite me having the rear window demister on for a reasonable chunk of time and having nearly-neat screenwash in the bottle. To say this was a nuisance was an understatement (it's rare that I try and drive in the spray of dirty water kicked up by HGV's, but it enabled me to clean my windscreen.)
All the symptoms were of frozen wash jets, but I tried pouring hot coffee on them to thaw them out and this made no difference at all. Therefore it is possible that the heaters in the jets were working, but the fluid had frozen further back in the pipes (about which there isn't much you can do, I guess.)
So, how do you test to see whether the heaters in the wash jets are operational, and are they known to fail?
ETA: An ancillary question; do they have heated wing mirrors as well? Do they come on at the same time - with the rear window demist switch?
Quickie.
