I've got a problem with the heater hot air valve for the passenger side. It is not getting a signal to open from the control unit in the dash. I've swapped the valve for the working drivers side and the problem stays with the passenger side. I'm wondering if anyone has had similar problems and suggestions to sort it? I've had the dash control out but there is nothing obvious amiss (to me anyway!).
Heater controls
- Thread starter desj1
I would guess there is a fuse for each of the heater servo devices. So may be a fuse blown. Do you have a fault code reader/resetter (like the Durametric system)? If the system has detected a faulty passenger side valve maybe it locks it out until the diagnostic system is reset?? I'm just guessing.
clyde
From memory it's only the heater control unit that's fused. If it's not powering the motorised valve from the other side (and I would put a multimeter on to make sure) I think the probelm must be in the contol unit itself.
Before condemming the control unit I would make sure all contacts are clean and it may be worthwhile getting your hands on a wiring diagram and trace and check the continuity of the supply wires from the contol unit to the valve just to make sure that there's not a problem there. It's also fairly easy to check whether the motorised valve is working with a 12 volt DC supply - I use the transformer from my Scalextric []
I believe there are firms out there that can overhaul the control unit if need be.
