Heater Disc Valve
berg944
How does the heater disc valve work?
Does it work from engine temperature (to warm up quicker)
or is it controled by the heater temperature switch
I have just changed the coolant and now my disc valve leaks at the operating arm so I will need a new one.
Mike
I think it is controlled by the hot/cold flap servo motor which in turn is controlled by the heater control. As the servo motors are electric and the water valve is vacuum there must be another piece to the puzzle.
Does it matter if you are just replacing it?
Tony
