Right, first of many questions I'm sure. Learning about these cars fast!
In the quest to not have warm air pumping into the cabin all the time, I have found that the heater valves off the heat exchangers are a bit sticky and don't fully close over when the switch is set to off. If I crawl under the car and close them by hand they will stay closed, so for now I have just left them closed and not touched the heater. Copius soaking with WD40 doesn't seem to have helped, and it seems it is the valves sticking not the cables as they are slack when the valve it shut.
As a long term solution I am thinking of just replacing the flapper boxes, but I did notice that one of the 3 studs looks missing on the drivers side, and the remaining nuts are a bit rusty. The other side all seem to be there ( harder to see from under the car with it still on the ground) I am now worried that I have at least one sheared off stud and trying to undo the rest may result in more shearing off. I want to plus gas them all for a while which should help a lot, but getting hold of it seems difficult - Halfords no longer stock it. Has anyone else had any of these stud shear and if so what is a good fix?
I think if it is only one and if the others come of then I can live with that, the boxes seem to have a good seal and don't carry any load, but what happens if more come off when trying to undo?
