Heater not always hot
- Thread starter Guest
No suggestions, sorry. There are various problems (documented on here) about heater control arms coming unclipped and then not activating the vents as they should, but this wouldn't be affected by day/night.
Are you sure you are leaving enough time for it all to warm up? I don't get hot air for a good 10 minutes after a cold start.
sawood12
berg944
climate control
I think that is only on certain models/dates or an optional extra?
Mine don't have sensors............look under the little grill on the dash (post 85)
Mike[:'(]
sawood12
The problem the post is about will be due to broken clip I expect. It has nothing to do with day/night and everything to do with the ambient air temp being used as the cold air in the blend fed to the cabin.
Regardless, no hot air at night, no matter how long or short the journey. Plenty of hot air during the day, but as was pointed out, I don't drive with lights on during the day. How does does having my lights on affect the heating?
And somebody mentioned a broken clip? What clip, and where do I look?
berg944
It shouldn't, but what else do you do differently at night [How does does having my lights on affect the heating?
Broken clips normally default to full heat, it is designed that way so the more easterly Europeans don't freeze to death [And somebody mentioned a broken clip?
Mike[:'(]
See, see, I said that too! I was right! I was right! >Notes the date to celebrate it in years to come!<ORIGINAL: Fen
ORIGINAL: zcacogp, some time ago
Take out the glove box liner for access and the clip holds two linkage rods next to the centre of the dash. It's so cheap I'd just replace it anyway while you're in there even if it turns out to be intact. If it isn't the clip other things to check are that there is no lint blocking the bulkhead end of the temp sensor hose, that the hose is connected to the vent in the dash and that the vacuum line that controls the flaps in the scuttle is connected and doesn't have any holes or crimps in it.
