heater not working
marcone
Hi I have 91 964 with no heater fan working but trying to understand how they work.Does the 2 fans under the bonnet for air con and the 1 in the back for the heat.If so how does the fan control work can somebody help
Hello... Are any of your fans working? If you have nothing at all then check the 25a fuse in slot 1 in the fuse box in the front boot. If you have fans but no heat then check the 25a or 30a fuse in the fuse box in the engine compartment. That was originally 25a but often blew so was changed to 30a. Let us know how you go.
