Heater not working
- Thread starter Guest
dtunnicliffe
http://www.type-911.co.uk/gp_electrical.htm
and see if they have one. Looks like they do to me!
Dave
There has been heaps written about this on the net. Control unit between the seats is repairable. Fordy has a good point, check all fuses and relays.
Excellent article on Pelican at;
http://forums.pelicanparts.com/showthread.php?s=&threadid=65261&highlight=heater+repair+control+unit
Be prepared for a long detailed read - very professional, without the local BS we have here.
Type 911 also have some good tips on their website - under electrical heading I think.
Don't be fooled into thinking these are complex things - it just a bunch of switches, relays, and motors. Keep em clean and oiled and it will look after you.[
OPC's must love-em.
Peter
It'll probably be OK when it gets warmer![
I'm never a lot of help...I KNOW.
http://www.type-911.co.uk/images/exhausts/heatingtech1.jpg
http://www.type-911.co.uk/images/exhausts/heatingtech2.jpg
http://www.type-911.co.uk/images/exhausts/heatingtech3.jpg
http://www.type-911.co.uk/images/exhausts/heatingtech4.jpg
http://www.type-911.co.uk/images/exhausts/heatingtech5.jpg
http://www.type-911.co.uk/images/exhausts/heatingtech6.jpg
As said elsewhere - once you get the hang of it it is actually fairly simple! You really need to isolate what you haven't got - is it heat - H/E boxes open so either cables or autoheat control (servo rod etc) or is it blowers (blower control relay in engine compartment or footwell relay in front fuse box).
In my experience you will get heat without any blowers so if you're freezing check your H/E boxes and cabling (they're sprung open if cables broken) and the 'snap-on' connector at the autoheat box first
By the way you can buy anything you need - the autoheat controller is expensive even for a Porsche part but all the blowers / relays / cables seem to be readily available
Good Luck
Roy
