fossil
Hi, I joined a while back when I purchased an '83 944. That deal fell flat on it's face and I've been hunting since, I have now purchased an 88 944s, guards red, 127k on the clock. - enough about me and the porker, on to my question.
The heater is constantly blowing hot air, I traced the vac pipes and found the heater control valve at the back of the engine works when you suck on the pipe to it and then the air in the car cools but I cannot get the heat control knob to do anything, even when it's set to cold there's hot air coming out the vents.
I can get one of the vac valves on the side of the heater to click when I press the recirc button but cannot get the other one to click.
The wiring diagram shows an internal temp sensor in the circuit but I have no idea where it is, my thoughts at the moment are either heat control knob not working or internal temp sensor not working. Do you guys have any other ideas of what it could be and how I can check.
thanks in advance.
Phil
thanks in advance.
Phil
