andrew holland
Hello all,
I wonder if anyone has come across this problem:
heater fan works fine on all 4 settings(speeds) but only if the temperature knob is turned to the coldest setting. As soon as I try to turn up the temp the fan will switch off . All wires are corectly connected to thre heater box on the engine . I suspect a fault with the heater head unit ?
Anyone with an answer ?. I would be very grateful considering the weather is getting cooler by the day !
Andrew .
993 c4 (96)88000miles .
Andrew .
