Heater problem
- Thread starter Guest
steh
if they do then your pron=blem is the heater boxes not closing, which is what is probley happening .
start the car and get some one to sit in it and if you look under the left or right hand side towards the under side of rear seats you will see the heater boxes, get the person in the car to turn on the heater and the cables should move the flaps on the boxes, if not then that is the cause.
steve
This links says the same.
http://members.rennlist.com/imcarthur/911autoheat.htm
Amo
IanHighfield
Exactly the same as my car, and yes the heater control valve is stuck in the 'closed' position thus letting all the hot air from the heat exchanger in to the cabin.
I just opened this when is was fitting my new 9 X 16 rear wheels / tyres. I spoke to Steve from Jaz when he was in Stratford for the Tour Britannia, and he explained it was an 'easy' job to remove and replace with a new part. The cable that controls the valve is another story - see Bones post on the SC forum if I recall correctly.
A winter project coming up.
Take N/S rear wheel off follow heat exchanger flexible ducting from front of heat ex is joined to the heater control valve. Jubilee clip for ducting and 3X 5mm nuts holding valve to body of car. 1/4 drive ratchet with 8mm socket will do the trick, over a pit is ideal. Valve is about £50.
Regards Baz
