The in cabin heater doesn't seem to work properly in my 964, I do not have air con.
Now, I understand that the heater system is not the best design in the world but the fans will only blow air around the cabin if the heater is set below 21 celcius. Otherwise although hot air comes through the vents it is appears only to be passively (i.e. very dependent on the car moving) and thus ineffective but occasionally will blast into life at motorway speeds for about 2 seconds).
On checking the electrics (and replacing some blown fuses which were not blower related (cigar lighter and aerial booster) I noticed that the relay (R14) for the blower was a VAG/Audi part.
Is this a known replacement because it's cheaper than the porsche part or is it a bodge to get the blower working in some form?
Could there be another simple reason for the way the heating system is working (i.e. that is how it is meant to work!)?
Thanks for any help
Chris
Thanks for any help
Chris
