Bought a set of heatexchangers last month from ebay (turned out they were from Porsca-part who I use quite regularly) almost brand new, original Porsche Part No 930.211.029.01 these were labelled as SC/Turbo excangers-1983, when the time has come to see how they fit it turns out they from a 3.2 (SC heat exchangers are 930.211.025.01), where they marry up to the engine at the exhaust ports these exchangers have a 6mm lip that stands proud of the flange where the gasket should sit flush, I have contacted Porsca-part and they assure me they came from a 3.0 SC, they don't have a problem taking them back, however the problem will be getting a set as good for the money.
I wondered if any of you know if it is possible to just cut the lip off so they will sit flush, are there any other real differences other than this lip.
