BKE has a little problem with his heating and air con:-
Pushing the air con button blows a fuse! This fuse also seems to control the heating and air direction baffles. This is a bit of a pain as, whilst one can currently live without air con, heating is becomming a favouable option.
I can stop myself pushing the air con button, and things are fine, untill I push the windscreen quick clear button when the fuse blows again. I'm on my last 7.5 amp fuse so haven't tried the recirculating air button yet.
In normal Porsche complexity the fan is on a different fuse.
Question: Does the windscreen quick clear switch also turn on the air con to dry the air?
If the answer to this is yes I can look at the air con as having the electrical fault. If the answer is no it then could be the control module.
