My two footwell fans run all the time even when the control is set at 0 and the relay in the engine compartment removed. The documentation that came with the car shows that there was a problem with the fans in the past that required a new relay which I assume was replaced. I checked the footwell motors and note that there is a spade fuse wired into each feed wire which seems odd as I don't think spade fuses were used in 1988.
Also...
Tried to remove the headlight to replace the unit as the reflective coating is poor. Coloured bezel screw came out, main screw is cross threaded (no I'm not turning the beam adjusters!) Any idea how to get the unit off? I was thinking of carefully breaking the glass and pushing the screw from behing until it bites.
Also...
