Greetings
I managed to get my heating system working correctly a few weeks ago, it had a few faults not just one
Firstly, the engine mounted blower had worn bearings so the armature seized and popped a fuse, new motor =£149.
Then I checked the flapper boxes, you can disengage the lever from the box between the seats and operate the cable manually, with a squirt or four of WD40, both flaps opened and closed as they should, deep joy.
Now to remove the central control box, I found a couple of micro switches had shifted out of position so the cam assy. wasn't operating them correctly and a found a soldered joint which had broken free so the lead was floating in fresh air! Repaired that lot and refitted the control box.
However the two footwell fans where still not working as they should. With the aid of the good ol' BENTLEY workshop manual I traced the dissappearing voltage problem back to that relay, left of the engine. Took the relay out and opened it up in my workshop and hey presto found a burnt track. After 20 years of passing just too much current the little cooper track had given up! So soldered in a short piece of wire to bridge it and re-assembled the relay.And popped it back into the car.....wait for it.
Bingo[
] now all fans work as they should, more joy (opens can of celebration beer).
Oh and the last thing I had to replace was the fresh air fan under the front scuttle, again worn bearings. It made a hell of a racket when switched on.
The only thing left to do on the heating side of things is too free up the demist lever cable but luckely it's jammed in the "demist" position.
A little summer job methinks.
Any way hope this little tale helps you in your search for heat![8D]
