On Sunday I decided the time had come to start to fix a non essential item that I have done without during my 12 years of ownership; get the heating working properly.
Having removed the engine blower motor without much trouble, I tested it by applying 12v power and found it wasn't working. Strip down showed that someone had tried to repair before and the fan ran out of true. So have decided to buy a new one (any ideas where; they all seem to be about £140).
While I was about it I decided to check if that was all that was wrong. The engine compartment relay works OK; I swopped it for the horn one to check. The fuses in the engine compartment seem OK.
What I can't find is any power getting to the wriing connector to supply the motor. I assume that it is activated by the ignition being switched on; or does it require the starter to be actually operated/engine running?
I think that the console housing the auto control and emergency override lever also contains wiring from the ignition switch, and therefore one or other has to be activated to switch on the blower motor? Is it accessible without taking out one or other of the front seats? The auto control doesn't do anything so maybe there is a power problem there rather than in the engine compartment.
Anyway any ideas gratefuly received!
![Spanner 2 [sm=spanner2.gif] [sm=spanner2.gif]](/forum/styles/default/pcgb/spanner2.gif)
