Hi Philip, the heating and ventilation can be confusing, the way I see it the cold and hot systems are separate and not combined as we are used to elsewhere. Basically you can run both systems at the same time, or chose one. You are probably most familiar with the fresh air controls, up until now, using the top two levers in the dash.
The hot system is the third dash lever with the red knob, combined with the centre heat control between the seats. This controls the separate hot air blowers behind the front wheel arch covers and another over the engine to deliver the hot air.
Try the systems individually and see how you get on. I assume any issues you may find will be related to the hot side of things. There are a couple of common faults regarding the hot system so let us know how you get on and you should get lots of advice from the Forum community.
(I see you have possibly inadvertently posted this thread twice so I'll remove the second thread this evening)
Steve
Steve
