Heel & Toe..?
- Thread starter garrettn
The 997 seat goes back further (away from the pedals) so that may be the only difference?
But if there is a pedal mod I'd be interested.
Pickled Piper
The easiest way to do this is to pull the accelerator pedal sharply upwards. This will disengage the ball joint directly below it. You can then adjust the length of the rod that joins to the accelerator cable mechanism. IIRC there is a hex shaft (10mm) with a lock nut. Loosen the lock nut and turn the hex shaft until the rod is at the height you require. Nip up the lock nut and snap the pedal back onto the ball joint.
It's a lot easier to actually make the adjustment then describe it. I effectively raised the position of my accelerator pedal relative to the brake pedal. This now allows me to articulate my foot whilst braking and dab the throttle pedal.
Good luck.
pp
(the one referred to by Michael)
ORIGINAL: Pickled Piper
..... I found that the position of the acclerator was adjustable.
The easiest way to do this is to pull the accelerator pedal sharply upwards. This will disengage the ball joint directly below it. ....
Hi,
I've just been out trying to do this and I must be missing something.
I've done plently of sharp upwards pulling and the pedal is solid as rock. It seems to be fastened to the floor with a hinge and the rod behind it seems well fastened to it also.
When you say "upward" I assume you mean pull the top part of pedal back toward the driver's seat - so the bottom of the pedal stays attached to hinge/floor?
I guess the "ball joint" is on the adjustable rod?
If someone can confirm that, I'll go and have a sharper pull at it!
I can find nothing in the workshop manual, except in a section on adjusting kick-down for tips - where it suggested "unhooking" the rod - but I can't see how you'd do this.
Mark
Alex Postan
Pickled Piper
ORIGINAL: marke2
Hi,
Mark
Ball is on the end of the rod and the socket is part of the pedal. It sounds like you are doing the right thing. You do have to pull hard and quite sharply. Put your hand behind the pedal and you should be able to feel the ball and socket.
Good luck.
pp
