Hello All [
After much hardwork and a big promise to myself I have finally achived a Porsche 911. Its a 1979 3.0 SC, am very happy with it, it needs a bit of work, but working on cars is what i love, so look forward to it.
I have a few questions, I would be very gratefull if someone could answer. I'm a time seasoned VW mechanic (air and water cooled) but Porsche 911 is a new one for me. The car has 58,000 miles (belived original, and I am in the south west of england).
Oil Questions
A) The guage next to the fuel gauge? Is that Oil Level? Is it normal for it to start in the red with the engine idling from cold, and then stabilize. Where is the best place for it? It seems to start in the red and settle near the top when idling on a level surface with the engine warm. I checked the engine oil at the time, but it seems to be quite a bit over the maxiumum, with LOADS of little tiny bubbles in it (normally thats a head gasket indicator on water cooled engine)
Oil pressure, seems to be a piddly 1 bar at Idle when warm, and about 3 bar max, when at speed (engine warm). Is this good, medium or bad?
I think Ive heard a little puff of white smoke is perfectly acceptable on a 911 at start up - any comments?
Which Oil should I use for an Oil Change 15/40 Semi, or a straight weight oil like SAE 30? Should I use Two cans of engine flush, because of the amount of oil in the system (no oil cooler in front wheel well on mine)?
Engine Tuning.
Ive found the idle speed adjustment, where is the CO adjustment? I have access to a CO machine and all the right tools plus know how. Should I am for a CO of say 2.5% at idle, once I have set/checked the ignition timing
I have a few other questions, like do you remove the engine and gearbox to change the clutch, but I will ask those at a later date.
OWNERS MANUAL
Anyone know of a owners manual in .PDF format? If not I'll keep a good look on ebay for one. Anyone reccomend any particular books for the SC?. I allready have a haynes manual and a few Porsche 911 buyers guides, red book, etc
MANY THANKS for taking the time to read this, and would very much appreciate any usefull comments
Luke
Oil Questions
Engine Tuning.
OWNERS MANUAL
Luke
