bmnelsc
I have a 1991 944 S2 RoW car - came from Japan with Left Hand Traffic ecode H4s (single bulb) and M605 - vertically adjustable headlights with the rotary switch on the console. Here in Canada this is a rare option - sealed beams were standard in NA so I'm having no luck obtaining information on this setup. I've changed the headlights to Right Hand Traffic ecodes but I need some help with adjusting.
Regarding the retaining frame which holds the adjusting screws and motor. The top right is a threaded shaft with philips head for left/right adjustment. Bottom left is threaded shaft with philips head for up/down adjustment and Top left is knurled shaft with a plain head which seems to be an anchor point. Can this knurled shaft be turned to alter the baseline setting or is it "fixed" in the retaining frame? I'm asking because the bottom left up/down adjustment on the motor seems to be screwed in all the way (which leaves no more room for making basic adjustments).
Sorry if this is simple stuff for you but getting these parts in Canada is a big deal and pretty expensive so I'm worried about breaking things while experimenting. Thank you.
Bruce Nelson (Edmonton, Alberta, Canada)
1991 944 S2 Coupe (sun roof delete)
