Jonathan G
Hi, the throttle pedal on my 2002 3.2S is loose. When gently pulling it backwards it flops back with no resistance (bottom hinge is fine). I believe that the metal "ball" end on the throttle unit (has rubber bellows around it) should locate in the socket on the back of the plastic pedal? Can anyone confirm this and advise how I get the back of the plastic throttle pedal properly located with the "ball" end of the throttle unit again?
Many thanks.
Many thanks.
