Steve Rance
Non member
Hi Guys. I have a brake cooling duct replacing the front side lights on my race car. I want to keep them as part of my restoration as I believe that the additional cooling will help. The problem is that I'm not sure where to fit my front side lights. I am hopeful that they can be re located in the body of the main front light assembly. I noticed that you have the same ducts on your car Steve, how did you get around it? Anyone got some info? Also, I would like to shorten the final drive ratio if possible. Is the hardware readily available, has anybody done this and do they recommend it?
Steve R
Steve R
