help! brake pad warning light
- Thread starter 3.2_fordy
Dekker
The 1st one is Front Left wheel and the last is Right Rear, so a continuity check should show near zero ohms. From there it goes to the Central Electric and Central Informer, not sure exactly what they are but suspect that one is a module.
After 4 years being laid up, I should imagine corrosion is the main problem and that unpluging the sockets of the modules and spaying with some contact cleaner and checking the ground points by cleaning any dull metal surfaces with fine sand paper back to bright metal.
I would also give the car a good thrashing with some high speed braking as you know the pads are good so no damage can ensue.
