knightrider
Hi Guys
My car is a 2006 997.1 CS2 but I was hoping somebody with knowledge here might be able to help me. When I went out today and backed my car off the driveway I noticed a patch of oil left in the area of the drivers side rear wheel under the car. I had a look underneath the car from the back and can see an area saturated with oil from where it is dripping slowly.
I have taken 2 photos and uploaded them so hopefully someone will know what is the likely cause of this leak? I had both the RMS and IMS seals replaced under warranty in Feb 2011 just before my warranty expired (at the time the RMS was only weeping slightly) and since then I have noticed the car has used a lot more oil (before the seals were changed it didn't drink a drop of oil in 2000 miles, since the RMS/IMS work the car has 'used' 1.5 litres in 1200 miles).
I am not completely sure that the car hasn't been leaking oil for a longer time period as I may not have noticed the patch before.
I am out of warranty now, is it possible that the RMS/IMS seals were not replaced correctly or is the area that the oil is dripping from completely unrelated?
Thanks in advance for any help.
