help, carrera 4s 2004
- Thread starter Guest
If you mean you see caramel coloured 'gunk' inside the oil filler pipe and cap that is not uncommon and nothing to worry about.
If however, you see it in your expansion tank (the left side of the engine compartment which contains coolant), then as you mentioned, you probably have serious issues.
adrian996
Seriously though, I really did turn the car down on the this basis as (like yourself) the last time I'd seen anything like this it was on an old Morris 1000 which had a tea bag for a head gasket. I was convinced that one of the heads on this (6,500 mile) 996 had popped!
Well time is a good healer for extreme embarrassment as well as pain and I subsequently discovered that it's a "normal" quirk of this car. The people from the OPC even 'phoned their head mechanic at home for me to talk to! But I couldn't be swayed. I'm stood in a service station with a large banker's draft looking at an otherwise lovely 911 with what I'm convinced is a popped head! Let's be honest, it's just not going to happen is it?
After doing (a lot) of research, which I thought that I'd already done, I wired them the cash and got it trailered down to me. I'd love to have heard the conversation between the two guys from the OPC on their way back to Aberdeen though!
The oil filler pipe is quite long. When your engine gets hot small amounts of condensation form in the filler pipe. This mixes with oil that lays in the pipe and creates the Dijon. It's now 14,000 miles later and mine still does it - but to varying degrees. I notice it more in the colder weather. This is because the filler end of the pipe is that much colder than the end that leads into the engine, I guess.
Hope this helps. Adrian.
