Hi Guys!
I got in my 944 (1983, n/a, 2.5L) thismorning, and as i pressed the clutch pedal, it slammed to the floor and didnt return, I opened the bonnet & saw that the fluid resevoir was completely empty, accompanied by a puddle on the floor.
This leads me to believe that the slave cylinder may be the culprit, as i can't see any leakage from the top of the engine bay/bulkhead / master cyl / inside the driver's footwell and all the connecting rods seem good.
I topped the resevoir up with dot4 and was hoping to see it leak, but as expected, that would be too easy and the pedal is not any better. I'm guessing that there's an air-lock between the master and slave cyl's.
My questions therefore are:
- How easy is the clyinder to replace, and how long will it take?
- what other components need to be removed 1st?
- where is the best place to buy a new one? (cheapest)
- any other ideas what it may be???
Cheers Guys! looking forward to reading the replies!
Regards,
James.
