Just returned from picking up a set of nicely refurbished teledials, happy as Larry, then the mood changed as I came of the M1 when the play in the clutch pedal changed.
A few miles on and the normal play that you get for the first cm of travel, drastically extended. The pedal doesn't spring back any more in line with the brake pedal, but sits about half way down; but, from that point you can pull it back to its normal position by hand.
I can still change gear, but where it is sitting in the middle of the full extent of its travel is fairly near the biting point.
Any ideas guys? [&:]
