Hilux
944 turbo (928 calipers)
How?
Are the wires a male push fit into the top of the sensor? Mine have a wire going into the middle of the top of the sensor with a spring steel clip each side that appears only to grip the wire insulation.
If not then how is the sensor replaced?
The sensor cannot move up and out of the pad as far as I can see.
I`ve got about 6mm of pad left and consider that I`d better change them as I`ve a track day coming up.
PS: whats all this about stuck on vibration damper thingy`s?
How?
