Help I need a speed/power check
- Thread starter Guest
ORIGINAL: johno
The car will not start with both centre cables removed = no spark
I pulled the primary and it still runs so my guess is the belt is woking on the secondary.
Isn't the primary shaft driven?
Primary distributor is driven from the crankshaft so if the engine starts and runs with the primary disabled, then the belt should be OK
I pulled each one off in turn, and as it ran on either one I did not get two hung up on which was the primary [
How many miles has the car done?, does it feel "off" at any particular speed, or generally flat?
I had the spark plug leads replaced on my old 3.2 once, and it felt like I had gained about 50 Bhp [
Pete
It feels like its losing power at 3-6k range, just doesnt have the pick up unless you really give it a thrashing!
This means I don't quite get that kick in the back when overtaking or trying to do full power roll on etc.
and its done 125k
I'm booked in to TWG for them to look at it but they couldn't get it in before Aug 10!
bones
38F3E1
Never had a decent explanation other than "but they are such a b*tch to do".
Ian.
ORIGINAL: bones
I know 911 plugs are tricky to get out but 24k is too much even if that is what the service schedule says. I don't pretend to know better than Porsche engineers but just do the little bugger a favour and change the plugs every 10,000 miles, I do mine on my SC every 6,000. Has the air filter been changed recently? The point made about the plug leads is a good one too, also check the state of the rotors in the distrubutors and the dizzy caps and all their connections including the the coil.
That would explain the OPC telling me every service is a major on the 964 then!
Wife used the car for day last week while low on fuel, enough to get there and back but she put a spot in anyway
She used a garge I dont but still used hi oct
Now the car seems to pull much better and the temp outside has dropped?
I've been using Tesco 98 ron could it be bad fuel?
Full service, inc plugs changed, and check on power loss.
Cat is nearly on its way out and the sensor is stuck in it, they belive this is effecting the power as the senor is also jamed. They belive this is 90% of the power loss problem combined with the hot air temp in the last few weeks.
New sensor on order and do i want to replace cat or bypass?
From a cost point of view I'll do the bypass, anything else I should know?
