Help leaking sunroof!!
cococola
Went to the car this morning following all that rain last night and both front seats were wet[:'(]Upon close inspection it seems to be coming from rhe lh and rh front hinge areas.
Would I be right in thinking I need to buy a new sunroof seal or could there be something else?[8|]
Thanks in advance guys!
Alan
If your seals are ok then your sunroof drains could be blocked, but be careful if you poke anything down them to clean them as I've heard you can push the drain tube off its connector.
