Help!! Locked out
picopro19k78
Hi all. Just been to the 944 to fire her up and run for a bit etc but am locked out. The battery must be flat but the key doesn't appear to open the doors or boot manually.
Any ideas?
The drivers door should open, although the hatch doesnt have a mechanical link on late cars. If you cant get in then I would suggest cutting away the rear quarter glass rubber seal with a craft knife. Carefully remove the anodised aluminium trim and keep it safe. Then cut away the seal until you can remove the glass. The whole glass, seal and trim is virtually worthless (unless youre dealing with an 'eBay breaker' or one of the ten bob millionaires 'dismantling' the cars now, often found on forums) and an established breaker (Paul Higginson, for example) will sell you a good one for a couple of pounds plus postage.
After Id written that, I hoped that you wouldnt think that I was meaning you, Alasdair. I thought that Id made the same offer too btw, although Im far less reliable... [:D]
