All, I need your help again.
After reading all the RMS threads and your replies (many thanks), I took the car in for the RMS to
be replaced. While the OPC had all the back end of the car off, they said about replacing the clutch as
it was partly worn or so they say. (the car has only done 31000 miles). I told them to go ahead and they knocked a £100 off as a goodwill gesture = Total cost £850.
I got the car back and had a smile on my face, looking forward to many more miles motoring.
On the second day of driving the car I started to notice that 1st and 2nd gear were really hard to get
into (more so when changing down gears). When the car warms up it isn't as abad but is still bad.
I took it back to my OPC and they said the cables under the car probably needed loosening. So booked it in and got the car back with it no better. They booked it in again only this time to replace the clutch. I got the car back yesterday only for it to be still the same. This time they said the clutch did not need replacing and they adjusted the cables again and THAT THERE IS A PROBLEM WITH MY GEARBOX.
I'm so angry - there was nothing a matter with my GEARBOX, NOR CLUTCH, before I took it.
The OPC have now said that they will replace the clutch again (after me insisting so) even though this is not a clutch issue.
Can any of your kind selves give me any advise.
Andy [
Andy [
