We are trying to sort out a problem that is puzzling my highly experienced Porsche specialist who has known my car since new. The car has the 930/50 type engine, with the earlier type Bosch fuel distributor 013 and no fuel accumulator.
The problem we have is overfuelling on initial start up, resulting in having to crank the engine over for 7-8 seconds with the throttle fully open, before it clears and the engine starts. This is a new problem as previously it was an instant starter. He thinks that the fuel distributor piston doesn't appear to stay in the down (no fuel delivery) position after an extended stop. As soon as the fuel pumps are triggered, fuel is injected until the piston returns to its correct position. This only takes 1 or 2 seconds but temporarily floods the engine, giving excessive fuel "wash" and then takes 7-8 seconds to clear and start.
Bosch have overhauled the fuel distributor and warm up regulator and new injectors have been fitted. Fuel delivery system pressure is to spec, as is fuel control pressure. The sensor plate within the metering unit is correctly positioned. Fuel pressure retention is also to spec. The problem is present whether the electric starting valve on the metering unit is connected or not. It has only shown itself since fitment of the new injectors, which are now keeping the injection lines filled with fuel where the previous worn injectors were "dribbling" fuel.
Any help on this problem will be much appreciated. Would lack of a fuel accumulator have any bearing on the problem, such that fitting one would be worthwhile? Would it actually be detrimental to fit one with the type 013 fuel distributor, as they were only factory fitted with the later 016 type?
Photo attached of the car when new, showing (non factory approved) alternative use of the rear spoiler
