davidharrow
I've removed the air box, Airflow meter, heater fan and both ducts. I've removed all 12 inlet manifold nuts.
The whole inlet assembly is free, but will only lift a few millimeters up and I reckon I need to lift it 15mm - 20mm to be able to replace the gaskets - Is there something else that holds them, probably behind the engine where I can't see ?
Any help much appreciated. Thanks. David
