Hi Everyone,
My 987 S Boxster brakes need a fairly heafty shove to stop the car quickly compared to my more modern everyday cars. Has anyone else noticed this, or is it just my car? I put new discs on the front last year but the pads were ok so I re-surfaced then and re-used them. The rear pads were renewed about the same time. I have since changed the brake fluid and bled the brakes. They still don't feel as good as they should to me.
Could the pistons be a bit stiff when coming out of the calipers, or could it be the rubber brake hoses stretching or could it be a servo issue - ie inadequate servo assistance. Could it be the vibration dampers?
The car just passed its MOT last week with no advisories and no comments from the tester.
Frankly I'm at a loss now as to what to check and hope some of you have had the same issue and managed to find the cause.
Any suggestion would be gratefully received.
Paul
Paul
