help with my 944 sunroof
- Thread starter Guest
Diver944
Prepare for a very long read, there are lots of setup and adjustment checks [8|]
ORIGINAL: ryan 944
hi my sunroof is not undoing on the one,so i can't take it out,any idea's thanks ryan
Is your car an early model or a later (after 85.5) model. The sunroof mechanisms are different. Also are you trying to operate it correctly. On mine if you shut the roof or if its already shut, you turn the ignition key to the off position but leave the key in, then hit the sunroof up switch which disengages the catches and allows you to remove the panel. Mine is pre 85.5. On later models I think the procedure is the same only instead of turning the ignition key completly off you turn it to position 1.
Diver944
ORIGINAL: ryan 944
it unlocks on one side only
Ah that's a better description [] It sounds like the one of the cogs or latches is misaligned. Clarks will tell you how to line them all up ok
wblackw9
I have a similar problem to you, my sunroof will only drive half way open then one side stops. A main drive cable comes from the motor to the white gear box behind the roof lining, from there it transfers the drive to either side via the gears and cables. The cables have a spiral effect and this is what the gear drives, if this is stripped or stretched on one side that may be your problem.
