Help with rough running
- Thread starter Stig_GT3
Stephenjk
I went for a drive yesterday and the car started running rough it was stalling and lack of power, if I accelerated it would also stall. it was drivable at around 2000 revs in second or third so I nursed it home. Now it is back home and if I start it idles at 200 revs and will die if I don't have my foot on the accelerator.
I swapped the DME with a new one and made no difference (DME had been replaced in the last few months anyway). I took apart the distributers and checked the secondary belt, which is fine and looks new. I also checked the motronic error codes with scantool and that is clean, no errors.
I still have the old bosch coils so do you think that is the issue and if so is there a way to test for that? I have seen a sensor issue could cause that too but hoping that would be generating an error code if that was the case. Thoughts?
thanks
Stephen
mcgc0
Stephenjk
mcgc0 said:At least the DME relay is ruled out. Is it rough idle from cold or only once warmed up? Random or intermittent is the pain in the butt scenario - as you say, sensors, coil pack etc. You have a respectable indie you can get to for plug-in diags and readout, just to eliminate sensors or any other readings?
it first started when hot. it would restart yesterday when hot. This morning when the car is cold it won't even start, it picks up and splutters and dies whether I put my foot on the accelerator or not. I'll try again later but I'm going to have to try and fix it at home, now at least so it runs enough to get to an indie.
mcgc0
mcgc0
Stephenjk
Stig_GT3 said:Quick thought: how old is the fuel in your car?
It's worth keeping in mind that fuel deteriorates over time, so if your car has not been used for a few months it might need some fresh super unleaded...
Good luck and enjoy the driving!
Just as an aside, my tank is getting low, fuel light on yesterday & I was thinking that I had only filled it up a few months ago. Turns out, I last filled up October last year. I'm ashamed to say I have only driven 330 miles since last October [&o]
Point is, the fuel has been in the tank for over 8 months and she runs like a dream and pulls like a train. I am still going for at least a 20 mile drive every couple of weeks, hopefully off to the South of France at the end of August, fingers crossed.
mcgc0
colin129 said:... hopefully off to the South of France at the end of August, fingers crossed.
Perfect - makes up for the loss of the Le Mans trip mid-June..
Stephenjk
mcgc0 said:This is the problem for which there was a Technical Bulletin released for, no? #9005.
yes this one.
https://rennlist.com/forums/964-forum/264897-technical-bulletin-t1-90-maf-wiring-harness-mod.html
i have that mod, though i haven't taken apart the clip to check exactly how it was done. I can see the wires are not coming straight out as they were pre mod. Instead they are coming out wrapped around the clip so they stay very close to the MAF. The clip has a cable tie around it so i did wonder whether it was a proper job. Anyway I doubt the heating is interfering but it could be the mod has fatigued the wires.
mcgc0 said:colin129 said:... hopefully off to the South of France at the end of August, fingers crossed.
tbh, we had always planned to miss the Toyota show, looking forward to the changes for next year though.
