hartge bob
Been out getting used to my new turbo and come across a peculiar problem.
On part throttle there seems to be a moments hesitation which sounds like the turbo is boosting then stalling then boosting again very quickly. The feeling is not unlike you sometimes used to get with a car on carbs when the chokes would take a second or two to spluttering before clearing. It sometimes clears itself after a few seconds but sometimes requires a lift followed by another bootful to get it going.
It is particularly noticeable on motorway / dual carriageway cruising where you are more likely to be on and off the throttle without actually flooring the throttle. The problem doesn't manifest if the throttle is floored under the same circumstances so I don't think it can be overboost protection cutting in. On full throttle there is just a gradual build up in speed until the boost builds up when the speed increases a bit quicker [
] (boost enhancer on the way)
Has anyone else ever come across this or have any ideas?
Rob
Rob
