scam75
Well-known member
Afternoon all
I suspect my HG is needing replaced. Have a water leak that I can see no sign of so the head will have to come off. Put a standard one on 60k ago but suspect when my wastegate diaphragm let go the 27 psi of boost I got up to may have hastened the demise of my HG! Mods are in sig below. Boost peaks at 21 psi in 5th dropping to 18psi due to MBC. Should I go with Victor Reinz again or upgrade to cometic or widefire??
Stuart
Stuart
