Hibernating
jez_anderson
Anyone any suggestions how best to store a 944 car for periods of 1 to 2 months? Do I need a battery conditioner etc?
I guess you're garaged right? If you think the car is secure, then I would disconnect the battery. Of course that means your alarm won't work, so maybe check with you insurance company first? Failing that, yep. a battery conditioner will do the job. Get one with a failsafe though that won't overcharge it. (i.e. don't skimp!)
While it's stored, keep the bonnet fully open too. It recharges the gas pressure in the struts!
I have an Optimate which does me just fine on my "always" garaged TR8. I've also heard reasonably good things about CTEK stuff. Demon tweeks have them both, but I'm sure a google will be able to get them cheaper than the Welsh boys!
I use and recommend www.carcoon.co.uk
Costs 39.99 inc delivery and VAT and comes with a slim lead that does not damage the tailgate seals. It also has two seperate connection methods. A couple of rings that can be permanently bolted to the battery terminals and a set of croc clips that you can temporarily use on a second car [:D]
Is it just me, or does that Carcoon one look EXACTLY the same as the optimate (different sticker obviously! [:D] )
ORIGINAL: Diver944
I've bought one. Is it alright to leave the thing connected and close the rear hatch? Is there enough ventilation for this? If I cant I cant lock the car up, so I assume I can?
How long is the 12v cable on the carcoon?
Will it work on calcium batteries?
I emailed them months ago but got no answer.
Mike[:'(]
ORIGINAL: jez_anderson
I would think it'll be OK. Just open the windows a 1/4 inch to let a bit of air circulate to be safer (if you're garaged of course)
So I found another advantage of owning a left-hooker.... The battery is in a sensible place for trickle chargers! [:D]
ORIGINAL: berg944
Mike[:'(]
Should do. Generally the Calcium batteries are "more heavy duty" than the standard lead/acid type.
Yep, I've been doing it like that for years.
The 12v lead is about 5 metres long, and the 240v lead into the box abour 3 metres. I 'think' they also sell an extra long 12v lead for an extra charge
Had trouble with the Carcoon charger - it wouldn't work. So I arranged to swap it with them for another one, nice people. I went to the factory in a scary part of manchester, not really what it expect it would be but the good news is the replacement works fine. Got talking to the people there, they make the car bubbles for Minardi F1 you know.
